HP Pavilion dm4-1265dx Wi-Fi Card Replacement
  1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 2, image 1 of 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 2, image 2 of 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 2, image 3 of 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: step 3, image 1 of 2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: step 3, image 2 of 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 4, image 1 of 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 4, image 2 of 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 4, image 3 of 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: step 5, image 1 of 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: step 5, image 2 of 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Using ESD safe tweezers, gently disconnect the black and white wires connecting the Wi-Fi card to the device.
    • Move the wires out of the way to allow the Wi-Fi card to spring up without obstructions.
  6. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 6, image 1 of 2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 6, image 2 of 2
    • Remove the two 3.0 mm screws from the Wi-Fi card using a Phillips #0 screwdriver.
  7. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 7, image 1 of 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 7, image 2 of 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: step 7, image 3 of 3
    • The Wi-Fi card will spring upwards.
    • Gently remove the Wi-Fi card by pulling it away from its socket.
Mason Hall
231 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 237
