HP Pavilion dv1000 Battery Replacement
  1. HP Pavilion dv1000 Battery Replacement, Battery: step 1, image 1 of 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Battery Replacement: step 2, image 1 of 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Battery Replacement: step 3, image 1 of 2 HP Pavilion dv1000 Battery Replacement: step 3, image 2 of 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Battery Replacement: step 4, image 1 of 3 HP Pavilion dv1000 Battery Replacement: step 4, image 2 of 3 HP Pavilion dv1000 Battery Replacement: step 4, image 3 of 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
John Park
273 Reputation
2 Guides authored
Cal Poly, Team 10-37, Forte Spring 2011 Member of Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Members
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 4,588
