HP Pavilion dv1000 RAM Replacement
  1. HP Pavilion dv1000 RAM Replacement, Battery: step 1, image 1 of 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 RAM Replacement: step 2, image 1 of 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 RAM Replacement: step 3, image 1 of 2 HP Pavilion dv1000 RAM Replacement: step 3, image 2 of 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 RAM Replacement: step 4, image 1 of 3 HP Pavilion dv1000 RAM Replacement: step 4, image 2 of 3 HP Pavilion dv1000 RAM Replacement: step 4, image 3 of 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 RAM Replacement, RAM: step 5, image 1 of 1
    • Locate RAM access door on the bottom side of the laptop.
  6. HP Pavilion dv1000 RAM Replacement: step 6, image 1 of 3 HP Pavilion dv1000 RAM Replacement: step 6, image 2 of 3 HP Pavilion dv1000 RAM Replacement: step 6, image 3 of 3
    • Locate the two screws holding down the RAM access cover
    • Unscrew the two screws with a size 00 Philips screwdriver.
    • Note: The screws do not detach from the cover.
  7. HP Pavilion dv1000 RAM Replacement: step 7, image 1 of 2 HP Pavilion dv1000 RAM Replacement: step 7, image 2 of 2
    • Lift up on the screw side of the RAM access cover to remove it.
  8. HP Pavilion dv1000 RAM Replacement: step 8, image 1 of 2 HP Pavilion dv1000 RAM Replacement: step 8, image 2 of 2
    • Gently pull apart the metal tabs located on both sides of the stick of RAM.
    • The RAM stick should tilt upwards.
  9. HP Pavilion dv1000 RAM Replacement: step 9, image 1 of 1
    • Gently lift the the RAM up and out of its seat.
  10. HP Pavilion dv1000 RAM Replacement: step 10, image 1 of 1
    • Repeat the previous two steps for the remaining stick of RAM.
5 other people completed this guide.
Henry OBrien
104 Reputation
1 Guide authored
Cal Poly, Team 10-37, Forte Spring 2011 Member of Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Members
9 Guides authored
2 Comments
THANKS - YOU'RE AWESOME!!!! Removing the hard drive was the fix it! the HP site never tells you this - imagine.......
marena - Reply
I had never dealt with laptop ram before and i used this guide sussusfully to remove the ram from my old HP Pavilliondv6-3055dx laptop. Thanks!
Andrew Lonero - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 8,922
