HP Pavilion dv2000 Hard Drive Replacement
  1. HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
    • Flip your computer over, so that the underside of your computer is facing upward.
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate the hard drive casing on the bottom-right corner of your flipped computer.
    • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
    • Screws on hard drive casing will remain in casing after being unscrewed.
  2. HP Pavilion dv2000 Hard Drive Replacement: step 2, image 1 of 3 HP Pavilion dv2000 Hard Drive Replacement: step 2, image 2 of 3 HP Pavilion dv2000 Hard Drive Replacement: step 2, image 3 of 3
    Phillips #000 Screwdriver
    $5.49
    Buy
    • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
    • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
7 other people completed this guide.
Erik Muniz
820 Reputation
3 Guides authored
CSU Fullerton, Team 2-3, Bruce Fall 2014 Member of CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Members
4 Guides authored
One Comment
You didnt mention this HDD has a different SATA connector , I cant find it in the market, instead of plug in , this one is for pressing down only
tml215 - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 4,398
