HP Pavilion dv4-4141us Fan Replacement
  1. HP Pavilion dv4-4141us Fan Replacement, Back Panel: step 1, image 1 of 1
    • Lift up the back panel using a spudger, and remove it from the device.
  2. HP Pavilion dv4-4141us Fan Replacement: step 2, image 1 of 3 HP Pavilion dv4-4141us Fan Replacement: step 2, image 2 of 3 HP Pavilion dv4-4141us Fan Replacement: step 2, image 3 of 3
    • Using the Phillips #1 screwdriver unscrew the panel from the computer.
    • Lift the panel up and remove it from the laptop.
  3. HP Pavilion dv4-4141us Fan Replacement, Hard Drive: step 3, image 1 of 3 HP Pavilion dv4-4141us Fan Replacement, Hard Drive: step 3, image 2 of 3 HP Pavilion dv4-4141us Fan Replacement, Hard Drive: step 3, image 3 of 3
    • Use the spudger to lift the left side of the hard drive.
    • Unplug the hard drive and remove it from the device.
  4. HP Pavilion dv4-4141us Fan Replacement, Fan: step 4, image 1 of 2 HP Pavilion dv4-4141us Fan Replacement, Fan: step 4, image 2 of 2
    • Use a Phillips #1 Screwdriver to remove all the screws indicated in the pictures.
  5. HP Pavilion dv4-4141us Fan Replacement: step 5, image 1 of 1
    • Use opening tool to separate the Key board and mouse pad.
    • It would be best to find a tool that is small enough to fit and start on the bottom at either corner and slide across lifting the panel up.
    • Be careful not to push too far underneath to not damage the interior and also it is advised to not bend or crack the plastic back cover.
  6. HP Pavilion dv4-4141us Fan Replacement: step 6, image 1 of 1
    • Use a spudger to gently lift the white plastic flap and release the ribbon cable holding the keyboard in place.
  7. HP Pavilion dv4-4141us Fan Replacement: step 7, image 1 of 2 HP Pavilion dv4-4141us Fan Replacement: step 7, image 2 of 2
    • Use the spudger to lift up the flap and release the cable for both of these two separate components.
    • Be extra careful not to break these clips as they are fragile and are a part of the motherboard.
  8. HP Pavilion dv4-4141us Fan Replacement: step 8, image 1 of 1
    • Unclip the last wire holding the motherboard in place. To do this pull down on the wire in the direction of the arrow.
  9. HP Pavilion dv4-4141us Fan Replacement: step 9, image 1 of 2 HP Pavilion dv4-4141us Fan Replacement: step 9, image 2 of 2
    • Take out the mother board and flip it over so that you can access the fan.
    • Unscrew the two screws holding the fan in place.
  10. HP Pavilion dv4-4141us Fan Replacement: step 10, image 1 of 1
    • Release the fan from the motherboard by disconnecting the wire from the fan.
Vincent Gardner
390 Reputation
3 Guides authored
One Comment
Thanks! I was able to upgrade my Intel Core i3 2330m to a considerably more powerful core i5 2410m! The instructions were very easy to follow. This fixed my problem!
Sam Watson - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 317
