HP Pavilion dv4000 RAM Replacement
  1. HP Pavilion dv4000  RAM Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000  RAM Replacement: step 2, image 1 of 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000  RAM Replacement: step 3, image 1 of 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000  RAM Replacement, RAM: step 4, image 1 of 1
    • Orient the laptop with the memory cover towards you.
  5. HP Pavilion dv4000  RAM Replacement: step 5, image 1 of 2 HP Pavilion dv4000  RAM Replacement: step 5, image 2 of 2
    • Unscrew the three 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000  RAM Replacement: step 6, image 1 of 1
    • Remove the memory cover.
  7. HP Pavilion dv4000  RAM Replacement: step 7, image 1 of 1
    • Pull the two tabs on both sides of the memory stick to release it.
    • The memory should pop up on its own with very little force applied to the tabs.
  8. HP Pavilion dv4000  RAM Replacement: step 8, image 1 of 2 HP Pavilion dv4000  RAM Replacement: step 8, image 2 of 2
    • Grab the memory stick from the sides with your fingers and set aside.
2 other people completed this guide.
Chris Marshall
454 Reputation
2 Guides authored
UMass Dartmouth, Team 4-2, Catania Fall 2016 Member of UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Members
6 Guides authored
One Comment
Hi, how much ram does this laptop support
Sébastien Grant - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,171
