HP Pavilion dv6-1245dx RAM Replacement
  1. HP Pavilion dv6-1245dx RAM Replacement, RAM: step 1, image 1 of 1
    • Shut down the computer and unplug it from the outlet.
    • All screws removed in this guide will require a Phillips #00 screwdriver.
  2. HP Pavilion dv6-1245dx RAM Replacement: step 2, image 1 of 1
    • Turn the computer upside down.
  3. HP Pavilion dv6-1245dx RAM Replacement: step 3, image 1 of 1
    • Loosen the three screws from the memory module compartment cover
    • Screws will not come all the way out.
  4. HP Pavilion dv6-1245dx RAM Replacement: step 4, image 1 of 1
    • Remove the memory module compartment cover.
  5. HP Pavilion dv6-1245dx RAM Replacement: step 5, image 1 of 3 HP Pavilion dv6-1245dx RAM Replacement: step 5, image 2 of 3 HP Pavilion dv6-1245dx RAM Replacement: step 5, image 3 of 3
    • Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
    • Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
    • If you are replacing both memory cards, repeat this step with the bottom memory card.
  6. HP Pavilion dv6-1245dx RAM Replacement: step 6, image 1 of 1
    • To replace the memory card, insert the card at a 45-degree angle, then push into slot.
    • Push down gently so the silver retaining tabs click back into place.
    • If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
4 other people completed this guide.
Jaime
562 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 2,375
