HP Pavilion dv6-2158nr Hard Drive Replacement
  1. HP Pavilion dv6-2158nr Hard Drive Replacement, Battery: step 1, image 1 of 3 HP Pavilion dv6-2158nr Hard Drive Replacement, Battery: step 1, image 2 of 3 HP Pavilion dv6-2158nr Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr Hard Drive Replacement, Hard Drive: step 2, image 1 of 3 HP Pavilion dv6-2158nr Hard Drive Replacement, Hard Drive: step 2, image 2 of 3 HP Pavilion dv6-2158nr Hard Drive Replacement, Hard Drive: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer.
    • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
  3. HP Pavilion dv6-2158nr Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion dv6-2158nr Hard Drive Replacement: step 3, image 2 of 2
    • Use the Mylar tab to lift the hard drive up, and then slide out to release it from the hard drive bay.
  4. HP Pavilion dv6-2158nr Hard Drive Replacement: step 4, image 1 of 3 HP Pavilion dv6-2158nr Hard Drive Replacement: step 4, image 2 of 3 HP Pavilion dv6-2158nr Hard Drive Replacement: step 4, image 3 of 3
    • Disconnect the hard drive cable from the system board.
    • Remove four 4mm screws from the hard drive case.
    • There are two screws on each side of the hard drive.
3 other people completed this guide.
Chad
1,123 Reputation
6 Guides authored
Cal Poly, Team 10-34, Maness Winter 2014 Member of Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 3,041
