HP Pavilion dv6-2158nr RAM Replacement
  1. HP Pavilion dv6-2158nr RAM Replacement, Battery: step 1, image 1 of 3 HP Pavilion dv6-2158nr RAM Replacement, Battery: step 1, image 2 of 3 HP Pavilion dv6-2158nr RAM Replacement, Battery: step 1, image 3 of 3
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr RAM Replacement, RAM: step 2, image 1 of 1
    • Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
  3. HP Pavilion dv6-2158nr RAM Replacement: step 3, image 1 of 3 HP Pavilion dv6-2158nr RAM Replacement: step 3, image 2 of 3 HP Pavilion dv6-2158nr RAM Replacement: step 3, image 3 of 3
    • Remove cover and expose the memory module by lifting the cover up like its on a hinge.
  4. HP Pavilion dv6-2158nr RAM Replacement: step 4, image 1 of 3 HP Pavilion dv6-2158nr RAM Replacement: step 4, image 2 of 3 HP Pavilion dv6-2158nr RAM Replacement: step 4, image 3 of 3
    • Locate the release tabs on both sides of the RAM.
    • Use non-conductive pointing tool or fingers to prevent static build up and damaging components.
    • Pull the metal tabs away from the memory to release it.
    • Pull RAM away from clips to remove from device
    • Repeat for second RAM if necessary
Chad
1,123 Reputation
6 Guides authored
Cal Poly, Team 10-34, Maness Winter 2014 Member of Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,539
