HP Pavilion dv6-6117dx Hard Drive Replacement
  1. HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion dv6-6117dx Hard Drive Replacement: step 2, image 2 of 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Hard Drive Replacement: step 3, image 1 of 3 HP Pavilion dv6-6117dx Hard Drive Replacement: step 3, image 2 of 3 HP Pavilion dv6-6117dx Hard Drive Replacement: step 3, image 3 of 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Hard Drive Replacement: step 4, image 1 of 3 HP Pavilion dv6-6117dx Hard Drive Replacement: step 4, image 2 of 3 HP Pavilion dv6-6117dx Hard Drive Replacement: step 4, image 3 of 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws holding the hard drive in place.
  5. HP Pavilion dv6-6117dx Hard Drive Replacement: step 5, image 1 of 3 HP Pavilion dv6-6117dx Hard Drive Replacement: step 5, image 2 of 3 HP Pavilion dv6-6117dx Hard Drive Replacement: step 5, image 3 of 3
    • Using a plastic spudger, lift up the hard drive from the top left corner and flip it to the right of the laptop like opening a book.
    • There is a cable connecting the hard drive to the laptop, be sure not to pull it out when flipping the hard drive.
  6. HP Pavilion dv6-6117dx Hard Drive Replacement: step 6, image 1 of 2 HP Pavilion dv6-6117dx Hard Drive Replacement: step 6, image 2 of 2
    • Pull the tab at the end of the cable connecting the hard drive to the laptop.
  7. HP Pavilion dv6-6117dx Hard Drive Replacement: step 7, image 1 of 3 HP Pavilion dv6-6117dx Hard Drive Replacement: step 7, image 2 of 3 HP Pavilion dv6-6117dx Hard Drive Replacement: step 7, image 3 of 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws on each side of the hard drive attaching it to its carriage.
  8. HP Pavilion dv6-6117dx Hard Drive Replacement: step 8, image 1 of 2 HP Pavilion dv6-6117dx Hard Drive Replacement: step 8, image 2 of 2
    • Remove the hard drive from its carriage.
  9. HP Pavilion dv6-6117dx Hard Drive Replacement: step 9, image 1 of 2 HP Pavilion dv6-6117dx Hard Drive Replacement: step 9, image 2 of 2
    • Remove the SATA cable from the hard drive.
4 other people completed this guide.
Joshua Holme
765 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 43
All Time: 2,535
