HP Pavilion dv6-6117dx RAM Replacement
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: step 1, image 1 of 2 HP Pavilion dv6-6117dx RAM Replacement, RAM: step 1, image 2 of 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: step 2, image 1 of 2 HP Pavilion dv6-6117dx RAM Replacement: step 2, image 2 of 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: step 3, image 1 of 3 HP Pavilion dv6-6117dx RAM Replacement: step 3, image 2 of 3 HP Pavilion dv6-6117dx RAM Replacement: step 3, image 3 of 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: step 4, image 1 of 2 HP Pavilion dv6-6117dx RAM Replacement: step 4, image 2 of 2
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: step 5, image 1 of 2 HP Pavilion dv6-6117dx RAM Replacement: step 5, image 2 of 2
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
Joshua Holme
765 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 22
All Time: 737
