HP Pavilion dv6000 Camera Replacement
  1. HP Pavilion dv6000 Camera Replacement, Camera: step 1, image 1 of 2 HP Pavilion dv6000 Camera Replacement, Camera: step 1, image 2 of 2
    • Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
    • If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 Camera Replacement: step 2, image 1 of 3 HP Pavilion dv6000 Camera Replacement: step 2, image 2 of 3 HP Pavilion dv6000 Camera Replacement: step 2, image 3 of 3
    • Press the tabs in on the sides of the screen and pop the plastic covering off.
    • The edges of the LCD screen are very sharp. Take care to not cut your fingers!
  3. HP Pavilion dv6000 Camera Replacement: step 3, image 1 of 1
    • Lift the screen out of the casing at the top near the camera.
    • Take care to not snap the plastic casing! It is brittle and still attached to the bottom of the screen.
  4. HP Pavilion dv6000 Camera Replacement: step 4, image 1 of 1
    • Gently remove the main cable from the camera.
  5. HP Pavilion dv6000 Camera Replacement: step 5, image 1 of 2 HP Pavilion dv6000 Camera Replacement: step 5, image 2 of 2
    • There are three clasps holding the camera down. Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings).
    • The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
  6. HP Pavilion dv6000 Camera Replacement: step 6, image 1 of 1
    • Remove the camera unit from the laptop and you are done!
3 other people completed this guide.
Ben Hirsch
3,841 Reputation
10 Guides authored
Cal Poly, Team 21-33, Regan Fall 2010 Member of Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 10,078
