HP Pavilion dv6500 RAM Card Replacement
  1. HP Pavilion dv6500 RAM Card Replacement, Battery: step 1, image 1 of 1
    • Flip computer face down.
  2. HP Pavilion dv6500 RAM Card Replacement: step 2, image 1 of 1
    • Remove the battery by sliding the button to the side.
    • Be careful if the battery is leaking or appears punctured in anyway. Battery acid is harmful and may cause burns.
  3. HP Pavilion dv6500 RAM Card Replacement, Back Panel: step 3, image 1 of 1
    • Remove fifteen 7.0mm PH0 screws.
    • Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
  4. HP Pavilion dv6500 RAM Card Replacement, RAM Card: step 4, image 1 of 3 HP Pavilion dv6500 RAM Card Replacement, RAM Card: step 4, image 2 of 3 HP Pavilion dv6500 RAM Card Replacement, RAM Card: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using your fingers or thin non metallic tweezers, pull the 2 silver levers on either side of the RAM card outward to until the ends pop up.
    • Slide the RAM cards out of their sockets.
4 other people completed this guide.
Andrew
392 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Catania Fall 2016 Member of UMass Dartmouth, Team 1-6, Catania Fall 2016
UMASSD-CATANIA-F16S1G6
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 21
All Time: 2,539
