HP Pavilion dv6500 Speaker Replacement
  1. HP Pavilion dv6500 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Remove all 4 of the 7.0mm screws and the 3 silver, smaller 4.0mm screws inside the cavity of the battery
  2. HP Pavilion dv6500 Speaker Replacement: step 2, image 1 of 2 HP Pavilion dv6500 Speaker Replacement: step 2, image 2 of 2
    • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
  3. HP Pavilion dv6500 Speaker Replacement: step 3, image 1 of 1
    • Gently pull on the 2 ribbon cables until they detach from the computer.
    • Unplug cables connecting the top keyboard assembly and computer body.
    • Be careful not to rip the speaker cables.
Andrew
392 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Catania Fall 2016 Member of UMass Dartmouth, Team 1-6, Catania Fall 2016
UMASSD-CATANIA-F16S1G6
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 771
