Introduction
If your HP pavilion dv6700 is producing excessive heat or the fans are very loud it most likely means that your heatsink is broken and you need to replace it. The heat sink works by attaching to a computer chip and absorbing the heat it produces, cooling it down and preventing the chip from overheating.
Warning: make sure to power down your device and to wear anti-static guard straps as you could damage the circuitry when coming into contact with static electricity.
Flip over the device so that the bottom is facing you.
Locate the battery on the bottom of your laptop.
Unscrew the black screw in the top right corner using the Phillips #00 screwdriver.
Pull up on the top piece and remove it.
Use a Phillips #0 screwdriver to loosen the 5 screws securing the heat sink to the motherboard.
5 other people completed this guide.
