HP Pavilion dv7-1448dx Key Replacement
  1. HP Pavilion dv7-1448dx Key Replacement, Key: step 1, image 1 of 1
    • Make sure the computer is unplugged and turned off.
    • Open the laptop so that the keyboard is fully exposed.
  2. HP Pavilion dv7-1448dx Key Replacement: step 2, image 1 of 1
    • Place the plastic opening tool in the crevice near the key that needs to be removed.
    • This works best if the tool is placed at the top of the key.
  3. HP Pavilion dv7-1448dx Key Replacement: step 3, image 1 of 1
    • Gently lever the tool downward until the key tilts upward.
    • At this point, move the tool around in order to completely pry the key off the keyboard. As the key is removed, small pops will be heard.
    • This step may take longer for larger keys.
    • When reinserting the key, gently press down until 2 clicks are heard (4 for larger keys).
  4. HP Pavilion dv7-1448dx Key Replacement: step 4, image 1 of 1
    • Carefully remove the key from the base.
  5. HP Pavilion dv7-1448dx Key Replacement: step 5, image 1 of 1
    • If the issue is a sticky key, make sure to clean the area once it is removed.
    • Use a cotton swab with alcohol to clean the underside of the key and the key slot.
Kirsten Gilliland
741 Reputation
4 Guides authored
Baylor, Team 3-5, Whitney Spring 2017 Member of Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
2 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 399
