HP Pavilion dv7-4285dx Hard Drive Replacement
  1. HP Pavilion dv7-4285dx Hard Drive Replacement, Battery: step 1, image 1 of 2 HP Pavilion dv7-4285dx Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Slide the battery release switch to the left. The battery pack will then subsequently release.
  2. HP Pavilion dv7-4285dx Hard Drive Replacement: step 2, image 1 of 1
    • Remove the battery pack from the socket.
  3. HP Pavilion dv7-4285dx Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 HP Pavilion dv7-4285dx Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 HP Pavilion dv7-4285dx Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Unscrew the 5 back plate screws using a Phillips #0 screwdriver.
    • During the removal process, the back plate will retain the 5 back plate screws.
    • Remove back plate using a metal spudger.
  4. HP Pavilion dv7-4285dx Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion dv7-4285dx Hard Drive Replacement: step 4, image 2 of 2
    • Remove the four 5.7 mm screws, holding down the hard drive, using a Phillips #0 screwdriver.
  5. HP Pavilion dv7-4285dx Hard Drive Replacement: step 5, image 1 of 3 HP Pavilion dv7-4285dx Hard Drive Replacement: step 5, image 2 of 3 HP Pavilion dv7-4285dx Hard Drive Replacement: step 5, image 3 of 3
    • Pull up carefully on tab hooking the hard drive to the mother board.
    • Remove the hard drive.
Austin Sandel
363 Reputation
3 Guides authored
IUPUI, Team S1-G2, Baechle Fall 2018 Member of IUPUI, Team S1-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G2
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 804
