HP Pavilion dv7-4285dx Keyboard Replacement
  1. HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: step 1, image 1 of 2 HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: step 1, image 2 of 2
    • Slide the battery release switch to the left. The battery pack will then subsequently release.
  2. HP Pavilion dv7-4285dx Keyboard  Replacement: step 2, image 1 of 1
    • Remove the battery pack from the socket.
  3. HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: step 3, image 1 of 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: step 3, image 2 of 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: step 3, image 3 of 3
    • Unscrew the 5 black plate screws using a Ph#0 screwdriver.
    • During the removal process, the back plate will retain the 5 back plate screws.
    • Use a metal spudger to carefully remove back plate.
  4. HP Pavilion dv7-4285dx Keyboard  Replacement: step 4, image 1 of 1
    • Unscrew the 7.2mm screws using a Ph#0 screwdriver.
  5. HP Pavilion dv7-4285dx Keyboard  Replacement: step 5, image 1 of 2 HP Pavilion dv7-4285dx Keyboard  Replacement: step 5, image 2 of 2
    • Push the keyboard release switch using the metal spudger.
  6. HP Pavilion dv7-4285dx Keyboard  Replacement: step 6, image 1 of 2 HP Pavilion dv7-4285dx Keyboard  Replacement: step 6, image 2 of 2
    • Lift up keyboard from its resting position.
  7. HP Pavilion dv7-4285dx Keyboard  Replacement: step 7, image 1 of 3 HP Pavilion dv7-4285dx Keyboard  Replacement: step 7, image 2 of 3 HP Pavilion dv7-4285dx Keyboard  Replacement: step 7, image 3 of 3
    • Lift up black tab holding ribbon cable.
    • Remove ribbon cable from motherboard.
  8. HP Pavilion dv7-4285dx Keyboard  Replacement: step 8, image 1 of 1
    • Remove keyboard.
Austin Sandel
363 Reputation
3 Guides authored
IUPUI, Team S1-G2, Baechle Fall 2018 Member of IUPUI, Team S1-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G2
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 459
