HP Pavilion dv7-6178us Hard Drive Replacement
  1. HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us Hard Drive Replacement: step 2, image 1 of 1
    • Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Take note of where you place the screws because you will need them for later.
  3. HP Pavilion dv7-6178us Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion dv7-6178us Hard Drive Replacement: step 3, image 2 of 2
    • Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop.
    • Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
2 other people completed this guide.
Zach Lunghi
148 Reputation
1 Guide authored
One Comment
This is a really GREAT thing that's being done!
It's high time that consumers fought back and stop letting the TECHNO-OVERLORDS, collectively STRIP us of the right to use the digital tools that we purchase from them.
Walter D Wormack - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 34
All Time: 2,046
