HP Pavilion dv7t-7000 Heat Sink Replacement
  1. HP Pavilion dv7t-7000 Heat Sink Replacement, Battery: step 1, image 1 of 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Heat Sink Replacement: step 2, image 1 of 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Heat Sink Replacement: step 3, image 1 of 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Heat Sink Replacement, Back Panel: step 4, image 1 of 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Heat Sink Replacement: step 5, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement: step 5, image 2 of 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Heat Sink Replacement, CD Drive: step 6, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement, CD Drive: step 6, image 2 of 2
    • Remove the single Phillips #00 screw.
  7. HP Pavilion dv7t-7000 Heat Sink Replacement: step 7, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement: step 7, image 2 of 2
    • Pull CD drive out to remove.
  8. HP Pavilion dv7t-7000 Heat Sink Replacement, RAM: step 8, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement, RAM: step 8, image 2 of 2
    • Push the retraining springs away from the RAM at the same time to unlock the RAM.
  9. HP Pavilion dv7t-7000 Heat Sink Replacement: step 9, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement: step 9, image 2 of 2
    • Pull the RAM out.
    • Follow the same procedure for the additional RAM.
  10. HP Pavilion dv7t-7000 Heat Sink Replacement, Hard Drive: step 10, image 1 of 1
    • Remove the two Phillips #00 screws holding in the hard drive.
  11. HP Pavilion dv7t-7000 Heat Sink Replacement: step 11, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement: step 11, image 2 of 2
    • Grab the black tab on the hard drive and pull left and then upwards to remove.
  12. HP Pavilion dv7t-7000 Heat Sink Replacement: step 12, image 1 of 1
    • Remove the four Phillips #00 screws holding the hard drive to its case.
  13. HP Pavilion dv7t-7000 Heat Sink Replacement: step 13, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement: step 13, image 2 of 2
    • Slide the casing off of the hard drive.
  14. HP Pavilion dv7t-7000 Heat Sink Replacement: step 14, image 1 of 1
    • Unplug the hard drive from the device.
  15. HP Pavilion dv7t-7000 Heat Sink Replacement, Wi-Fi Card: step 15, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement, Wi-Fi Card: step 15, image 2 of 2
    • Use the flat end of a spudger to pop off the antenna connectors.
  16. HP Pavilion dv7t-7000 Heat Sink Replacement: step 16, image 1 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement: step 16, image 2 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement: step 16, image 3 of 3
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
  17. HP Pavilion dv7t-7000 Heat Sink Replacement, Keyboard: step 17, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement, Keyboard: step 17, image 2 of 2
    • Flip the laptop over.
  18. HP Pavilion dv7t-7000 Heat Sink Replacement: step 18, image 1 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement: step 18, image 2 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement: step 18, image 3 of 3
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  19. HP Pavilion dv7t-7000 Heat Sink Replacement: step 19, image 1 of 1
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  20. HP Pavilion dv7t-7000 Heat Sink Replacement, Palm Rest: step 20, image 1 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement, Palm Rest: step 20, image 2 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement, Palm Rest: step 20, image 3 of 3
    • Flip the keyboard back over.
    • Remove the single Phillips #00 screw holding in the CD drive.
    • Pull out the CD drive.
  21. HP Pavilion dv7t-7000 Heat Sink Replacement: step 21, image 1 of 1
    • Remove the seventeen Phillips #00 screws securing the back panel to the laptop.
  22. HP Pavilion dv7t-7000 Heat Sink Replacement: step 22, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement: step 22, image 2 of 2
  23. HP Pavilion dv7t-7000 Heat Sink Replacement: step 23, image 1 of 1
    • Remove the panel by lifting it up.
  24. HP Pavilion dv7t-7000 Heat Sink Replacement, Motherboard: step 24, image 1 of 1
    • Remove the eleven Phillips #00 screws.
  25. HP Pavilion dv7t-7000 Heat Sink Replacement: step 25, image 1 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement: step 25, image 2 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement: step 25, image 3 of 3
    • Use the flat end of a spudger to disconnect all wires connected to the motherboard.
  26. HP Pavilion dv7t-7000 Heat Sink Replacement: step 26, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement: step 26, image 2 of 2
    • Lift up the black tab on the ZIF connector with the flat end of a spudger.
    • Pull the ribbon cable out of the ZIF connector.
    • Remove the fan from the laptop.
  27. HP Pavilion dv7t-7000 Heat Sink Replacement, Heat Sink: step 27, image 1 of 2 HP Pavilion dv7t-7000 Heat Sink Replacement, Heat Sink: step 27, image 2 of 2
    • Once you have removed the motherboard, the heat sink is attached.
    • Flip over the motherboard/heat sink assembly.
  28. HP Pavilion dv7t-7000 Heat Sink Replacement: step 28, image 1 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement: step 28, image 2 of 3 HP Pavilion dv7t-7000 Heat Sink Replacement: step 28, image 3 of 3
    • Remove the six screws holding the heat sink onto the motherboard.
    • Unplug the cord supplying power to the fan.
    • Pull the two pieces apart.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 702
