HP Pavilion dv7t-7000 RAM Replacement
  1. HP Pavilion dv7t-7000 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 RAM Replacement: step 2, image 1 of 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 RAM Replacement: step 3, image 1 of 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 RAM Replacement, Back Panel: step 4, image 1 of 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 RAM Replacement: step 5, image 1 of 2 HP Pavilion dv7t-7000 RAM Replacement: step 5, image 2 of 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 RAM Replacement, RAM: step 6, image 1 of 2 HP Pavilion dv7t-7000 RAM Replacement, RAM: step 6, image 2 of 2
    • Push the retraining springs away from the RAM at the same time to unlock the RAM.
  7. HP Pavilion dv7t-7000 RAM Replacement: step 7, image 1 of 2 HP Pavilion dv7t-7000 RAM Replacement: step 7, image 2 of 2
    • Pull the RAM out.
    • Follow the same procedure for the additional RAM.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 256
