HP Pavilion dv7t-7000 Wi-Fi Card Replacement
  1. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Battery: step 1, image 1 of 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: step 2, image 1 of 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: step 3, image 1 of 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Back Panel: step 4, image 1 of 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: step 5, image 1 of 2 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: step 5, image 2 of 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Wi-Fi Card: step 6, image 1 of 2 HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Wi-Fi Card: step 6, image 2 of 2
    • Use the flat end of a spudger to pop off the antenna connectors.
  7. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: step 7, image 1 of 3 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: step 7, image 2 of 3 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: step 7, image 3 of 3
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 193
