HP Pavilion dv9000 Keyboard Replacement
  1. HP Pavilion dv9000 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Keyboard Replacement, Battery Removal: step 2, image 1 of 2 HP Pavilion dv9000 Keyboard Replacement, Battery Removal: step 2, image 2 of 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Keyboard Replacement, Keyboard: step 3, image 1 of 2 HP Pavilion dv9000 Keyboard Replacement, Keyboard: step 3, image 2 of 2
    • Remove the six 5 mm screws in the battery compartment using Phillips #1 screwdriver.
    • Remove the 7mm keyboard screw located towards the center of the laptop with a Phillips #1 screwdriver.
  4. HP Pavilion dv9000 Keyboard Replacement: step 4, image 1 of 1
    • Flip the laptop over and open the lid.
    • Lift out the plastic panel containing the power button and flip it over.
    • Be careful, the panel is still attached by a small ribbon cable.
  5. HP Pavilion dv9000 Keyboard Replacement: step 5, image 1 of 3 HP Pavilion dv9000 Keyboard Replacement: step 5, image 2 of 3 HP Pavilion dv9000 Keyboard Replacement: step 5, image 3 of 3
    • Locate the ribbon cable attached to the underside of the plastic panel.
    • Using a spudger, unplug the ribbon cable by pushing the brown tab away from circuit board and sliding the ribbon out with your hand.
    • Set the plastic panel aside.
  6. HP Pavilion dv9000 Keyboard Replacement: step 6, image 1 of 3 HP Pavilion dv9000 Keyboard Replacement: step 6, image 2 of 3 HP Pavilion dv9000 Keyboard Replacement: step 6, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the three 5mm screws holding the keyboard in place.
    • Carefully lift the keyboard up (no more than a few cm) and slide it forward, towards the laptops monitor to reveal another larger ribbon cable.
    • Be extremely careful as the keyboard is still attached to the computer by the larger ribbon cable.
  7. HP Pavilion dv9000 Keyboard Replacement: step 7, image 1 of 3 HP Pavilion dv9000 Keyboard Replacement: step 7, image 2 of 3 HP Pavilion dv9000 Keyboard Replacement: step 7, image 3 of 3
    • Use a spudger to push the black tab forward and slide it away from the white connector.
    • Gently pull the ribbon cable from the connector housing.
    • Remove the keyboard.
Erik Hoffnagle
768 Reputation
3 Guides authored
Cal Poly, Team 10-32, Maness Winter 2014 Member of Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Members
6 Guides authored
One Comment
Please I have a problem with my hp laptop the keyboard and there is noise on it, repair it automatic. thanks you
Clement Glah - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 3,187
