HP Pavilion dv9000 RAM Replacement
  1. HP Pavilion dv9000 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 RAM Replacement, Battery Removal: step 2, image 1 of 2 HP Pavilion dv9000 RAM Replacement, Battery Removal: step 2, image 2 of 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 RAM Replacement, RAM: step 3, image 1 of 3 HP Pavilion dv9000 RAM Replacement, RAM: step 3, image 2 of 3 HP Pavilion dv9000 RAM Replacement, RAM: step 3, image 3 of 3
    • Locate the middle plastic cover on the bottom of the laptop.
    • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
    • Lift and remove the plastic cover.
  4. HP Pavilion dv9000 RAM Replacement: step 4, image 1 of 3 HP Pavilion dv9000 RAM Replacement: step 4, image 2 of 3 HP Pavilion dv9000 RAM Replacement: step 4, image 3 of 3
    • Locate the RAM card and the metal tabs on either side of it.
    • Press both tabs away from the RAM card to release it. The card should flip up towards you.
    • Carefully lift the RAM card out.
Erik Hoffnagle
801 Reputation
3 Guides authored
Cal Poly, Team 10-32, Maness Winter 2014 Member of Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 3,798
