HP Pavilion dv9000 Wireless Card Replacement
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: step 2, image 1 of 2 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: step 2, image 2 of 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: step 3, image 1 of 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: step 3, image 2 of 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: step 3, image 3 of 3
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: step 4, image 1 of 3 HP Pavilion dv9000 Wireless Card Replacement: step 4, image 2 of 3 HP Pavilion dv9000 Wireless Card Replacement: step 4, image 3 of 3
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: step 5, image 1 of 2 HP Pavilion dv9000 Wireless Card Replacement: step 5, image 2 of 2
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
2 other people completed this guide.
Erik Hoffnagle
768 Reputation
3 Guides authored
Cal Poly, Team 10-32, Maness Winter 2014 Member of Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 3,965
