HP Pavilion g4-1117dx Fan Replacement
  1. HP Pavilion g4-1117dx Fan Replacement, Battery: step 1, image 1 of 1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Fan Replacement, L-Shaped Back Panel: step 3, image 1 of 1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Fan Replacement: step 4, image 1 of 1
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Fan Replacement, Hard Drive: step 5, image 1 of 1
    • Pull out and unplug the tab on the right hand side.
  5. HP Pavilion g4-1117dx Fan Replacement, Larger Back Panel: step 6, image 1 of 1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. HP Pavilion g4-1117dx Fan Replacement: step 7, image 1 of 1
    • Remove 3 screws located where the battery previously was.
  7. HP Pavilion g4-1117dx Fan Replacement: step 8, image 1 of 2 HP Pavilion g4-1117dx Fan Replacement: step 8, image 2 of 2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. HP Pavilion g4-1117dx Fan Replacement: step 9, image 1 of 1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. HP Pavilion g4-1117dx Fan Replacement: step 10, image 1 of 1
    • Unplug wires connecting back panel to keyboard.
  10. HP Pavilion g4-1117dx Fan Replacement, Motherboard: step 11, image 1 of 2 HP Pavilion g4-1117dx Fan Replacement, Motherboard: step 11, image 2 of 2
    • In lower left hand corner, pull on black tab to unplug the disc drive.
  11. HP Pavilion g4-1117dx Fan Replacement: step 12, image 1 of 2 HP Pavilion g4-1117dx Fan Replacement: step 12, image 2 of 2
    • In upper left hand corner, unplug the large black electrical tape covered laptop plug.
  12. HP Pavilion g4-1117dx Fan Replacement, Fan: step 13, image 1 of 2 HP Pavilion g4-1117dx Fan Replacement, Fan: step 13, image 2 of 2
    • Unscrew the four screws JIS #0 screws on the back side of the motherboard.
    • Screws will loosen but do not come completely out.
    • The screws are the only thing keeping the fan attached to the motherboard.
Robert Hamilton
1,165 Reputation
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 2,020
