HP Pavilion g6-1b79dx RAM Replacement
  1. HP Pavilion g6-1b79dx RAM Replacement, Battery: step 1, image 1 of 1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx RAM Replacement: step 2, image 1 of 2 HP Pavilion g6-1b79dx RAM Replacement: step 2, image 2 of 2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx RAM Replacement: step 3, image 1 of 2 HP Pavilion g6-1b79dx RAM Replacement: step 3, image 2 of 2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx RAM Replacement, Bottom Panel: step 4, image 1 of 1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx RAM Replacement: step 5, image 1 of 1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx RAM Replacement: step 6, image 1 of 3 HP Pavilion g6-1b79dx RAM Replacement: step 6, image 2 of 3 HP Pavilion g6-1b79dx RAM Replacement: step 6, image 3 of 3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx RAM Replacement, RAM: step 7, image 1 of 3 HP Pavilion g6-1b79dx RAM Replacement, RAM: step 7, image 2 of 3 HP Pavilion g6-1b79dx RAM Replacement, RAM: step 7, image 3 of 3
    • Slide the two latches away from the RAM to unhook it.
  8. HP Pavilion g6-1b79dx RAM Replacement: step 8, image 1 of 3 HP Pavilion g6-1b79dx RAM Replacement: step 8, image 2 of 3 HP Pavilion g6-1b79dx RAM Replacement: step 8, image 3 of 3
    • Gently slide the RAM out from the laptop.
Rachel Gallegos
873 Reputation
5 Guides authored
Baylor, Team 10-12, Williams Fall 2015 Member of Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 922
