HP Pavilion g6-2228tx Optical Drive Replacement
  1. HP Pavilion g6-2228tx Optical Drive Replacement, Battery: step 1, image 1 of 2 HP Pavilion g6-2228tx Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Push the battery latch to the left to release the battery.
    • Remove the battery from the device.
  2. HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: step 2, image 1 of 2 HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: step 2, image 2 of 2
    • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
  3. HP Pavilion g6-2228tx Optical Drive Replacement: step 3, image 1 of 3 HP Pavilion g6-2228tx Optical Drive Replacement: step 3, image 2 of 3 HP Pavilion g6-2228tx Optical Drive Replacement: step 3, image 3 of 3
    • Place your hand on the cover and slide the cover down.
    • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
  4. HP Pavilion g6-2228tx Optical Drive Replacement: step 4, image 1 of 2 HP Pavilion g6-2228tx Optical Drive Replacement: step 4, image 2 of 2
    • Place one finger on the right side of the hard drive.
    • Push the hard drive to the left and lift the hard drive up to remove it from the device.
  5. HP Pavilion g6-2228tx Optical Drive Replacement: step 5, image 1 of 2 HP Pavilion g6-2228tx Optical Drive Replacement: step 5, image 2 of 2
    • Disconnect the connecting part by pulling the part to the right.
    • Remove the hard drive from the device.
  6. HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: step 6, image 1 of 2 HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: step 6, image 2 of 2
    • Remove the 2.5mm screw with a Phillips #0 screw drive.
  7. HP Pavilion g6-2228tx Optical Drive Replacement: step 7, image 1 of 3 HP Pavilion g6-2228tx Optical Drive Replacement: step 7, image 2 of 3 HP Pavilion g6-2228tx Optical Drive Replacement: step 7, image 3 of 3
    • Put one finger into the release hole and push to the left until part of the optical drive comes out from the left of the laptop.
  8. HP Pavilion g6-2228tx Optical Drive Replacement: step 8, image 1 of 3 HP Pavilion g6-2228tx Optical Drive Replacement: step 8, image 2 of 3 HP Pavilion g6-2228tx Optical Drive Replacement: step 8, image 3 of 3
    • Grab the optical drive and pull to the left to remove it from the device.
Hai Lin
446 Reputation
4 Guides authored
UC Davis, Team S4-G6, Lore Fall 2018 Member of UC Davis, Team S4-G6, Lore Fall 2018
UCD-LORE-F18S4G6
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 982
