HP Pavilion g7-1150us Surface Panel Replacement
  1. HP Pavilion g7-1150us Surface Panel Replacement, Battery: step 1, image 1 of 2 HP Pavilion g7-1150us Surface Panel Replacement, Battery: step 1, image 2 of 2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Surface Panel Replacement: step 2, image 1 of 1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Surface Panel Replacement, Surface Panel: step 3, image 1 of 1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Surface Panel Replacement: step 4, image 1 of 2 HP Pavilion g7-1150us Surface Panel Replacement: step 4, image 2 of 2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Surface Panel Replacement: step 5, image 1 of 1
    • Lift the pried surface panel off of the computer.
Kyle Dinunno
377 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 285
