HP Pavilion g7-1365dx Optical Drive Replacement
  1. HP Pavilion g7-1365dx Optical Drive Replacement, Battery: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Optical Drive Replacement: step 2, image 1 of 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Optical Drive Replacement, Service Door: step 3, image 1 of 2 HP Pavilion g7-1365dx Optical Drive Replacement, Service Door: step 3, image 2 of 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: step 4, image 1 of 3 HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: step 4, image 2 of 3 HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: step 4, image 3 of 3
    • Using the Phillips size 00 screwdriver, unscrew the 4.7 mm screw that holds the optical drive.
    • Use the opening tool to slide the drive out the side of the laptop to remove it.
Colin Klaes
259 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 163
