HP Pavilion g7-2023cl Hard Drive Replacement
  1. HP Pavilion g7-2023cl Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. HP Pavilion g7-2023cl Hard Drive Replacement: step 2, image 1 of 3 HP Pavilion g7-2023cl Hard Drive Replacement: step 2, image 2 of 3 HP Pavilion g7-2023cl Hard Drive Replacement: step 2, image 3 of 3
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
  3. HP Pavilion g7-2023cl Hard Drive Replacement, Service Door: step 3, image 1 of 2 HP Pavilion g7-2023cl Hard Drive Replacement, Service Door: step 3, image 2 of 2
    • Using a Phillips #0 screwdriver, loosen the service door screw.
    • This is a captive screw that will remain attached to the service door.
  4. HP Pavilion g7-2023cl Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion g7-2023cl Hard Drive Replacement: step 4, image 2 of 2
    • Lift the service door up and away from the device.
  5. HP Pavilion g7-2023cl Hard Drive Replacement, Hard Drive: step 5, image 1 of 3 HP Pavilion g7-2023cl Hard Drive Replacement, Hard Drive: step 5, image 2 of 3 HP Pavilion g7-2023cl Hard Drive Replacement, Hard Drive: step 5, image 3 of 3
    • Locate the hard drive cable connector pull tab.
    • Pinch the pull tab pulling upwards from the motherboard to disconnect the hard drive cable.
    • To reconnect the cable, align it so that the cable from the connector is facing the battery and the cable lays in the groove of the base enclosure.
  6. HP Pavilion g7-2023cl Hard Drive Replacement: step 6, image 1 of 1
    • Use a spudger or other ESD-safe prying tool to lift one side of the hard drive up and out of the base enclosure.
    • You may be able to lift up the hard drive with just your fingers.
  7. HP Pavilion g7-2023cl Hard Drive Replacement: step 7, image 1 of 2 HP Pavilion g7-2023cl Hard Drive Replacement: step 7, image 2 of 2
    • Grab the end of the hard drive.
    • Pull the hard drive out of the base enclosure at an angle.
    • To replace the hard drive, insert it at the same angle you removed it from and slide it back into the base enclosure until it lays flat.
Thomas Maloney
1,060 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 354
