HP Pavilion g7-2275dx Hard Drive Replacement
  1. HP Pavilion g7-2275dx Hard Drive Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: step 1, image 1 of 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  2. HP Pavilion g7-2275dx Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion g7-2275dx Hard Drive Replacement: step 2, image 2 of 2
    • Slide the back panel down and pull it up.
  3. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  4. HP Pavilion g7-2275dx Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion g7-2275dx Hard Drive Replacement: step 4, image 2 of 2
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
  5. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
    • Remove the black SATA cable from the hard drive.
  6. HP Pavilion g7-2275dx Hard Drive Replacement: step 6, image 1 of 2 HP Pavilion g7-2275dx Hard Drive Replacement: step 6, image 2 of 2
    • Remove the black rubber end caps.
  7. HP Pavilion g7-2275dx Hard Drive Replacement: step 7, image 1 of 2 HP Pavilion g7-2275dx Hard Drive Replacement: step 7, image 2 of 2
    • Remove the four silver 5 mm Phillips #1 screws from the hard drive.
  8. HP Pavilion g7-2275dx Hard Drive Replacement: step 8, image 1 of 1
    • Remove the plastic cover from the hard drive.
To reassemble or replace your hard drive, follow these instructions in reverse order with the working drive.
5 other people completed this guide.
Erik Miller
2,123 Reputation
4 Guides authored
Cal Poly, Team 11-51, Amido Spring 2014 Member of Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Members
21 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 4,975
