HP Pavilion tx2500 Fan Replacement
  1. HP Pavilion tx2500 Fan  Replacement, Screen Rotator: step 1, image 1 of 1
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
  2. HP Pavilion tx2500 Fan  Replacement: step 2, image 1 of 2 HP Pavilion tx2500 Fan  Replacement: step 2, image 2 of 2
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
  3. HP Pavilion tx2500 Fan  Replacement: step 3, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
  4. HP Pavilion tx2500 Fan  Replacement: step 4, image 1 of 1
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
  5. HP Pavilion tx2500 Fan  Replacement: step 5, image 1 of 1
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
  6. HP Pavilion tx2500 Fan  Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to disconnect the wires in the upper corners.
  7. HP Pavilion tx2500 Fan  Replacement: step 7, image 1 of 1
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
  8. HP Pavilion tx2500 Fan  Replacement: step 8, image 1 of 1
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
  9. HP Pavilion tx2500 Fan  Replacement: step 9, image 1 of 2 HP Pavilion tx2500 Fan  Replacement: step 9, image 2 of 2
    • Rotate the screen 90 degrees and remove the base under the screen.
  10. HP Pavilion tx2500 Fan  Replacement: step 10, image 1 of 1
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
  11. HP Pavilion tx2500 Fan  Replacement: step 11, image 1 of 2 HP Pavilion tx2500 Fan  Replacement: step 11, image 2 of 2
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
  12. HP Pavilion tx2500 Fan  Replacement: step 12, image 1 of 1
    • Gently lift up and remove the screen.
  13. HP Pavilion tx2500 Fan  Replacement, Fan: step 13, image 1 of 3 HP Pavilion tx2500 Fan  Replacement, Fan: step 13, image 2 of 3 HP Pavilion tx2500 Fan  Replacement, Fan: step 13, image 3 of 3
    • Disconnect the wire from the system board using the plastic opening tool.
    • Disconnect the wire from the optical drive using the plastic opening tool.
    • Gently lift the top cover from the tablet.
  14. HP Pavilion tx2500 Fan  Replacement: step 14, image 1 of 2 HP Pavilion tx2500 Fan  Replacement: step 14, image 2 of 2
    • Using the plastic opening tool, disconnect the plastic blue film from the tablet.
    • Disconnect the wire using the plastic opening tool.
  15. HP Pavilion tx2500 Fan  Replacement: step 15, image 1 of 2 HP Pavilion tx2500 Fan  Replacement: step 15, image 2 of 2
    • Lift the system board from the tablet.
    • Turn the system board over and lay it flat on a soft surface.
  16. HP Pavilion tx2500 Fan  Replacement: step 16, image 1 of 2 HP Pavilion tx2500 Fan  Replacement: step 16, image 2 of 2
    • Using a Phillips #00, remove the 4.5 mm screws that connect the fan to the board.
    • Using a plastic opening tool, disconnect the wire that attached the fan to the board.
  17. HP Pavilion tx2500 Fan  Replacement: step 17, image 1 of 1
    • Gently lift the fan away from the board.
Ricardo
164 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 1,085
