HP Pavilion tx2500 Screen Rotator Replacement
  1. HP Pavilion tx2500 Screen Rotator Replacement, Screen Rotator: step 1, image 1 of 1
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
  2. HP Pavilion tx2500 Screen Rotator Replacement: step 2, image 1 of 2 HP Pavilion tx2500 Screen Rotator Replacement: step 2, image 2 of 2
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
  3. HP Pavilion tx2500 Screen Rotator Replacement: step 3, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
  4. HP Pavilion tx2500 Screen Rotator Replacement: step 4, image 1 of 1
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
  5. HP Pavilion tx2500 Screen Rotator Replacement: step 5, image 1 of 1
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
  6. HP Pavilion tx2500 Screen Rotator Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to disconnect the wires in the upper corners.
  7. HP Pavilion tx2500 Screen Rotator Replacement: step 7, image 1 of 1
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
  8. HP Pavilion tx2500 Screen Rotator Replacement: step 8, image 1 of 1
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
  9. HP Pavilion tx2500 Screen Rotator Replacement: step 9, image 1 of 2 HP Pavilion tx2500 Screen Rotator Replacement: step 9, image 2 of 2
    • Rotate the screen 90 degrees and remove the base under the screen.
  10. HP Pavilion tx2500 Screen Rotator Replacement: step 10, image 1 of 1
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
  11. HP Pavilion tx2500 Screen Rotator Replacement: step 11, image 1 of 2 HP Pavilion tx2500 Screen Rotator Replacement: step 11, image 2 of 2
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
  12. HP Pavilion tx2500 Screen Rotator Replacement: step 12, image 1 of 1
    • Gently lift up and remove the screen.
Sarah Naiser
324 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 650
