HP Pavilion x2 10-n113dx Battery Replacement
  1. HP Pavilion x2 10-n113dx Battery Replacement, Battery: step 1, image 1 of 3 HP Pavilion x2 10-n113dx Battery Replacement, Battery: step 1, image 2 of 3 HP Pavilion x2 10-n113dx Battery Replacement, Battery: step 1, image 3 of 3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Battery Replacement: step 2, image 1 of 2 HP Pavilion x2 10-n113dx Battery Replacement: step 2, image 2 of 2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Battery Replacement: step 3, image 1 of 3 HP Pavilion x2 10-n113dx Battery Replacement: step 3, image 2 of 3 HP Pavilion x2 10-n113dx Battery Replacement: step 3, image 3 of 3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Battery Replacement: step 4, image 1 of 3 HP Pavilion x2 10-n113dx Battery Replacement: step 4, image 2 of 3 HP Pavilion x2 10-n113dx Battery Replacement: step 4, image 3 of 3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Battery Replacement: step 5, image 1 of 3 HP Pavilion x2 10-n113dx Battery Replacement: step 5, image 2 of 3 HP Pavilion x2 10-n113dx Battery Replacement: step 5, image 3 of 3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
4 other people completed this guide.
David Zambrano
822 Reputation
5 Guides authored
USF Tampa, Team S13-G4, Boczar Fall 2017 Member of USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 38
All Time: 5,008
