HP Pavilion x2 10-n113dx Touch Pad Replacement
  1. HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: step 1, image 1 of 2 HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: step 1, image 2 of 2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Touch Pad Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Loosen the adhesive under the gray plastic bar using a heat pad or a heat gun.
    • Remove the gray plastic bar after 5 minutes of light heat with tweezers by pulling up.
  3. HP Pavilion x2 10-n113dx Touch Pad Replacement: step 3, image 1 of 1
    • Remove the 4 screws with a Phillips #0 screwdriver.
    • These 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Touch Pad Replacement: step 4, image 1 of 2 HP Pavilion x2 10-n113dx Touch Pad Replacement: step 4, image 2 of 2
    • Remove the rubber stoppers at the top left and right with tweezers.
    • Remove the screws at the top and right with at Phillips #0 screwdriver.
    • These two screws have a diameter of 5.3 mm and a height of 4.3 mm.
  5. HP Pavilion x2 10-n113dx Touch Pad Replacement: step 5, image 1 of 3 HP Pavilion x2 10-n113dx Touch Pad Replacement: step 5, image 2 of 3 HP Pavilion x2 10-n113dx Touch Pad Replacement: step 5, image 3 of 3
    • Pry open the back case with a metal spudger.
    • Then pry open the back layer with the metal spudger.
  6. HP Pavilion x2 10-n113dx Touch Pad Replacement: step 6, image 1 of 2 HP Pavilion x2 10-n113dx Touch Pad Replacement: step 6, image 2 of 2
    • Fully take off the back panel by lifting up the panel.
  7. HP Pavilion x2 10-n113dx Touch Pad Replacement: step 7, image 1 of 2 HP Pavilion x2 10-n113dx Touch Pad Replacement: step 7, image 2 of 2
    • Pop open the ribbon cable piece on the touch pad with the blue plastic spudger.
    • Remove the ribbon cable with tweezers by pulling it out.
  8. HP Pavilion x2 10-n113dx Touch Pad Replacement: step 8, image 1 of 2 HP Pavilion x2 10-n113dx Touch Pad Replacement: step 8, image 2 of 2
    • Remove 4 screws with at Phillips #0 screwdriver. All 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
    • Lift the tape shown with orange boxes with tweezers.
    • Remove metal bar with a blue spudger.
  9. HP Pavilion x2 10-n113dx Touch Pad Replacement: step 9, image 1 of 3 HP Pavilion x2 10-n113dx Touch Pad Replacement: step 9, image 2 of 3 HP Pavilion x2 10-n113dx Touch Pad Replacement: step 9, image 3 of 3
    • Lift up the touch pad by the metal edge with a blue plastic spudger.
    • Remove the touch pad from the computer.
Cayla Skaggs
337 Reputation
2 Guides authored
IUPUI, Team S1-G4, Harley Spring 2019 Member of IUPUI, Team S1-G4, Harley Spring 2019
IUPUI-HARLEY-S19S1G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 719
