HP Pavilion x360 11-p110nr Key Replacement
  1. HP Pavilion x360 11-p110nr Key Replacement, Key: step 1, image 1 of 1
    • Use a screwdriver or other flat instrument to get under the key, and pull up slightly on one of the edges.
  2. HP Pavilion x360 11-p110nr Key Replacement: step 2, image 1 of 3 HP Pavilion x360 11-p110nr Key Replacement: step 2, image 2 of 3 HP Pavilion x360 11-p110nr Key Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Clear out any obstructions or crumbs that are jamming the key or the hinges underneath.
    • You may use a Q-tip, toothpick, or tweezers.
  3. HP Pavilion x360 11-p110nr Key Replacement: step 3, image 1 of 2 HP Pavilion x360 11-p110nr Key Replacement: step 3, image 2 of 2
    • Use the flat screw to put the key back into place.
    • Gently press the key down. It should snap back into place
Finish Line
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 3,308
