HP Pavilion x360 11m-ad013dx Battery Replacement
  1. HP Pavilion x360 11m-ad013dx Battery Replacement, Keyboard: step 1, image 1 of 1
    • Lay the HP Pavilion top-down with the front edge facing towards you.
  2. HP Pavilion x360 11m-ad013dx Battery Replacement: step 2, image 1 of 1
    • Remove the three 4.8mm Phillips #0 screws from the front side.
  3. HP Pavilion x360 11m-ad013dx Battery Replacement: step 3, image 1 of 2 HP Pavilion x360 11m-ad013dx Battery Replacement: step 3, image 2 of 2
    • Using a plastic spudger, remove the grey silicon strip closest to the back-side.
  4. HP Pavilion x360 11m-ad013dx Battery Replacement: step 4, image 1 of 1
    • Remove the three 5.7mm Phillips #1 screws.
  5. HP Pavilion x360 11m-ad013dx Battery Replacement: step 5, image 1 of 2 HP Pavilion x360 11m-ad013dx Battery Replacement: step 5, image 2 of 2
    • Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
    • Using a spudger, pry off the black keyboard panel.
    • This step requires force to unclasp the latches keeping the keyboard in place.
  6. HP Pavilion x360 11m-ad013dx Battery Replacement: step 6, image 1 of 2 HP Pavilion x360 11m-ad013dx Battery Replacement: step 6, image 2 of 2
    • Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
    • You may disconnect the other end of the cable, for ease of access to other parts. Keep in mind that the end labeled MB connects to the motherboard.
  7. HP Pavilion x360 11m-ad013dx Battery Replacement: step 7, image 1 of 2 HP Pavilion x360 11m-ad013dx Battery Replacement: step 7, image 2 of 2
    • Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
  8. HP Pavilion x360 11m-ad013dx Battery Replacement: step 8, image 1 of 1
    • Remove the keyboard.
  9. HP Pavilion x360 11m-ad013dx Battery Replacement, Battery: step 9, image 1 of 1
    • Remove the five 4.6mm Phillips #1 screws located around the battery.
  10. HP Pavilion x360 11m-ad013dx Battery Replacement: step 10, image 1 of 2 HP Pavilion x360 11m-ad013dx Battery Replacement: step 10, image 2 of 2
    • Using a spudger for assistance, lift up the right edge of the battery.
    • Remove the battery.
0 Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 19
All Time: 1,547
