HP Pavilion x360 11m-ad013dx Heat Sink Replacement
  1. HP Pavilion x360 11m-ad013dx Heat Sink Replacement, Keyboard: step 1, image 1 of 1
    • Lay the HP Pavilion top-down with the front edge facing towards you.
  2. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 2, image 1 of 1
    • Remove the three 4.8mm Phillips #0 screws from the front side.
  3. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 3, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 3, image 2 of 2
    • Using a plastic spudger, remove the grey silicon strip closest to the back-side.
  4. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 4, image 1 of 1
    • Remove the three 5.7mm Phillips #1 screws.
  5. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 5, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 5, image 2 of 2
    • Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
    • Using a spudger, pry off the black keyboard panel.
    • This step requires force to unclasp the latches keeping the keyboard in place.
  6. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 6, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 6, image 2 of 2
    • Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
    • You may disconnect the other end of the cable, for ease of access to other parts. Keep in mind that the end labeled MB connects to the motherboard.
  7. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 7, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 7, image 2 of 2
    • Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
  8. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 8, image 1 of 1
    • Remove the keyboard.
  9. HP Pavilion x360 11m-ad013dx Heat Sink Replacement, Battery: step 9, image 1 of 1
    • Remove the five 4.6mm Phillips #1 screws located around the battery.
  10. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 10, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 10, image 2 of 2
    • Using a spudger for assistance, lift up the right edge of the battery.
    • Remove the battery.
  11. HP Pavilion x360 11m-ad013dx Heat Sink Replacement, Speaker: step 11, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement, Speaker: step 11, image 2 of 2
    • Using your fingernail, disconnect the ZIF (zero insertion force) hard drive cable by flipping up the small locking flap.
  12. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 12, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 12, image 2 of 2
    • With your fingernails, disconnect the speaker cable from the motherboard by pulling back on the connector.
    • Do not directly pull on the wires, as this can damage the connector.
  13. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 13, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 13, image 2 of 2
    • Lift the speaker cable from its retention chamber.
  14. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 14, image 1 of 1
    • Remove the four 6.2mm Phillips #1 screws around the speakers.
  15. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 15, image 1 of 1
    • Remove the speakers.
  16. HP Pavilion x360 11m-ad013dx Heat Sink Replacement, Motherboard: step 16, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement, Motherboard: step 16, image 2 of 2
    • Using your fingernail, disconnect the ZIF (zero insertion force) power button connector cable from the motherboard.
  17. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 17, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 17, image 2 of 2
    • Using your fingernail, disconnect the ZIF display panel connector cable from the motherboard.
  18. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 18, image 1 of 3 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 18, image 2 of 3 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 18, image 3 of 3
    • Disconnect the two WLAN antenna cables by sliding under the cable with a spudger, then lifting straight up.
    • The black labeled cable inserts into the "A" connection. The white labeled cable inserts into the "B" connection.
  19. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 19, image 1 of 3 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 19, image 2 of 3 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 19, image 3 of 3
    • Using your fingernail, disconnect the ZIF display touch screen connector cable from the motherboard.
  20. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 20, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 20, image 2 of 2
    • Using your fingernails, disconnect the power connector cable by pulling straight out.
    • Do not directly pull the wires, as this can damage the connector. Instead, pull on the white, plastic part of the connector.
  21. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 21, image 1 of 1
    • Remove the eleven 4.6 mm Phillips #1 screws from around the motherboard.
  22. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 22, image 1 of 1
    • Remove the one 2.2 mm Phillips #1 broad head screw in the WLAN module.
  23. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 23, image 1 of 1
    • Lift the motherboard up on the right side. Then, gently pull the motherboard straight out to the right.
  24. HP Pavilion x360 11m-ad013dx Heat Sink Replacement, Heat Sink: step 24, image 1 of 3 HP Pavilion x360 11m-ad013dx Heat Sink Replacement, Heat Sink: step 24, image 2 of 3 HP Pavilion x360 11m-ad013dx Heat Sink Replacement, Heat Sink: step 24, image 3 of 3
    • Flip the motherboard over towards you.
  25. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 25, image 1 of 3 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 25, image 2 of 3 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 25, image 3 of 3
    • Loosen the four captive Phillips #1 screws.
    • Do not attempt to remove the captive screws; only loosen them.
    • Flip the heat sink up.
  26. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 26, image 1 of 1
    • Using a tissue or paper towel, clean thermal paste off the heat sink and processor.
    • New thermal paste, along with instructions for how to apply the paste, is provided with the purchased replacement heat sink.
  27. HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 27, image 1 of 2 HP Pavilion x360 11m-ad013dx Heat Sink Replacement: step 27, image 2 of 2
    • Remove the black electric tape attached to the shell of the memory module.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 361
