HP Pavilion x360 14m-ba011dx RAM Replacement
  1. HP Pavilion x360 14m-ba011dx RAM Replacement, Battery: step 1, image 1 of 2 HP Pavilion x360 14m-ba011dx RAM Replacement, Battery: step 1, image 2 of 2
    • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
    • Two 7.5 mm screws.
    • Three 5 mm screws.
    • One 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx RAM Replacement: step 2, image 1 of 1
    • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx RAM Replacement: step 3, image 1 of 2 HP Pavilion x360 14m-ba011dx RAM Replacement: step 3, image 2 of 2
    • Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
    • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
  4. HP Pavilion x360 14m-ba011dx RAM Replacement: step 4, image 1 of 2 HP Pavilion x360 14m-ba011dx RAM Replacement: step 4, image 2 of 2
    • Remove the purple cable attaching the battery to the motherboard by flipping the black flap and pulling the cable out.
    • Remove seven 4 mm screws using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx RAM Replacement: step 5, image 1 of 1
    • Remove the battery by gently pushing battery up, then pulling.
  6. HP Pavilion x360 14m-ba011dx RAM Replacement, Motherboard: step 6, image 1 of 2 HP Pavilion x360 14m-ba011dx RAM Replacement, Motherboard: step 6, image 2 of 2
    • Unclip the 5 cables connecting the motherboard to the computer.
  7. HP Pavilion x360 14m-ba011dx RAM Replacement: step 7, image 1 of 1
    • Remove ten 4 mm screws using a Phillips #00 screwdriver.
  8. HP Pavilion x360 14m-ba011dx RAM Replacement: step 8, image 1 of 1
    • Gently remove the motherboard.
  9. HP Pavilion x360 14m-ba011dx RAM Replacement, RAM: step 9, image 1 of 2 HP Pavilion x360 14m-ba011dx RAM Replacement, RAM: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Flip the motherboard upside down and remove the silver box covering the RAM sticks.
    • Using your fingers or a pair of tweezers, pull the edges of the card to the side and lift the RAM out of the motherboard.
One Comment
Don't forget the WIFI chip in step 7, take out the silver screw first before taking off the motherboard.
Jerri - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 3,100
