Introduction
If your HP Pavilion x360 14m-ba011dx laptop’s SSD is no longer functioning or perhaps you would like to expand the memory capacity of your computer, this guide will walk you through how to replace the SSD card.
Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
Two 7.5 mm screws.
Three 5 mm screws.
One 6.5 mm screw.
Flip the motherboard over to expose the SSD.
Using a Phillips #00 screwdriver, remove one 3 mm silver screw that holds the SSD in place.
