HP Pavilion x360 14m-cd0003dx Battery Replacement
  1. HP Pavilion x360 14m-cd0003dx Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Battery Replacement: step 2, image 1 of 2 HP Pavilion x360 14m-cd0003dx Battery Replacement: step 2, image 2 of 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Battery Replacement: step 3, image 1 of 3 HP Pavilion x360 14m-cd0003dx Battery Replacement: step 3, image 2 of 3 HP Pavilion x360 14m-cd0003dx Battery Replacement: step 3, image 3 of 3
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 other people completed this guide.
Mason T Arruda
171 Reputation
1 Guide authored
One Comment
Hallo
vielen Dank für diese coole Anleitung
als Ergänzung
beim Model 14-cd0101ng gibt es lediglich die beiden unteren Schrauben (siehe schritt, zwei 6mm schrauben) nicht.
Ansonsten konnte ich keine unterschiede feststellen!
Eng:
For Model 14-cd0101ng it is the same way, without the two 6mm Phillips screws underneath!
Erwin “ReudenBub” Po - Reply
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 52
All Time: 2,284
