HP Pavilion x360 14m-cd0003dx Fan Replacement
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: step 2, image 1 of 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: step 2, image 2 of 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: step 3, image 1 of 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: step 4, image 1 of 1
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: step 5, image 1 of 1
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: step 6, image 1 of 1
    • Remove the heat sink assembly from the device.
2 other people completed this guide.
Riley McMorrow
273 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 14
All Time: 544
