HP Pavilion x360 14m-cd0003dx Hinges Replacement
  1. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Screen: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to carefully separate the screen from the plastic frame.
    • Work along the top first, and then down the left and right sides.
  3. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 3, image 1 of 1
    • The screen can then be separated from the frame and laid flat on top of the keyboard.
    • Do not pull and try to remove yet, as the screen is still connected by several cables.
  4. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 4, image 1 of 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 4, image 2 of 2
    • The next few steps involve disconnecting the screen from the laptop in several places.
    • The first place is connected to the left side of the thin blue board at the top.
    • Peel back the clear adhesive and remove the pin header from the port on the blue board.
  5. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 5, image 1 of 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 5, image 2 of 2
    • The next place is underneath the gray adhesive. Peel back this adhesive to expose the connection underneath.
    • Disconnect the gold pin header from its port.
  6. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 6, image 1 of 1
    • Repeat Step 4 for the connection on the right side.
    • Peel the clear adhesive and remove connection.
  7. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 7, image 1 of 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 7, image 2 of 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 7, image 3 of 3
    • Peel the thin gray adhesive strips.
    • Pull out the thin black cable underneath these strips. It is the same black cable that was disconnected in the previous steps.
  8. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 8, image 1 of 1
    • After the cable has been disconnected, the screen can be removed.
  9. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Hinges: step 9, image 1 of 1
    • Remove the three Phillip Head screws (5 mm)that hold in the bracket on each side.
  10. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 10, image 1 of 1
    • Slide the frame down past the brackets on each side.
  11. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 11, image 1 of 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 11, image 2 of 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 11, image 3 of 3
    • Lay the laptop flat on your working surface.
    • Flip it over to get access to the back panel.
    • Remove the back panel screws and take off the back cover.
  12. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 12, image 1 of 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 12, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the 5 mm screws from the hinges on each side inside the laptop.
  13. HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 13, image 1 of 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: step 13, image 2 of 2
    • Remove the hinges from both sides of the laptop.
Elijah Jope
379 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 70
All Time: 2,658
