HP Pavilion x360 14m-cd0003dx SSD Replacement
  1. HP Pavilion x360 14m-cd0003dx SSD Replacement, SSD: step 1, image 1 of 1
    • Make sure computer is turned off
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx SSD Replacement: step 2, image 1 of 3 HP Pavilion x360 14m-cd0003dx SSD Replacement: step 2, image 2 of 3 HP Pavilion x360 14m-cd0003dx SSD Replacement: step 2, image 3 of 3
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx SSD Replacement: step 3, image 1 of 2 HP Pavilion x360 14m-cd0003dx SSD Replacement: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the 5 mm screw that secures the SSD.
  4. HP Pavilion x360 14m-cd0003dx SSD Replacement: step 4, image 1 of 2 HP Pavilion x360 14m-cd0003dx SSD Replacement: step 4, image 2 of 2
    • Peel back the black covering.
    • Pull out SSD.
Jack Benfeito
180 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 26
All Time: 930
