HP Pavilion x360 14m-cd0003dx Touchpad Replacement
  1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 2, image 1 of 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 2, image 2 of 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 3, image 1 of 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 3, image 2 of 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 3, image 3 of 3
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
  4. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: step 4, image 1 of 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: step 4, image 2 of 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: step 4, image 3 of 3
    • Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
  5. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 5, image 1 of 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 5, image 2 of 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 5, image 3 of 3
    • Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
    • Remove the metal plate that secures the touch pad.
  6. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 6, image 1 of 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: step 6, image 2 of 2
    • Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
    • Remove touch pad.
Elijah Jope
379 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 15
All Time: 430
