HP Pavilion x360 14m-cd0005dx Battery Replacement
  1. HP Pavilion x360 14m-cd0005dx Battery Replacement, Back Cover: step 1, image 1 of 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Battery Replacement: step 2, image 1 of 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Battery Replacement: step 3, image 1 of 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: step 3, image 2 of 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Battery Replacement: step 4, image 1 of 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: step 4, image 2 of 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Battery Replacement: step 5, image 1 of 3 HP Pavilion x360 14m-cd0005dx Battery Replacement: step 5, image 2 of 3 HP Pavilion x360 14m-cd0005dx Battery Replacement: step 5, image 3 of 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: step 6, image 1 of 3 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: step 6, image 2 of 3 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: step 6, image 3 of 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Battery Replacement: step 7, image 1 of 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: step 7, image 2 of 2
    • Carefully lift from the base and remove the battery.
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 15
All Time: 1,521
