HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement
  1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: step 1, image 1 of 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: step 1, image 2 of 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: step 1, image 3 of 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: step 2, image 1 of 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: step 2, image 2 of 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: step 2, image 3 of 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: step 3, image 1 of 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: step 3, image 2 of 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: step 3, image 3 of 3
    • Remove all three 3.5 mm screws using the Phillips #0 screwdriver.
    • Disconnect the cables above the fan.
    • Disconnect the wire next to the fan.
  4. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: step 4, image 1 of 1
    • Remove nine 4mm screws using the Phillips #0 screwdriver.
  5. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: step 5, image 1 of 1
    • Flip over the motherboard.
  6. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: step 6, image 1 of 2 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: step 6, image 2 of 2
    • Remove four 3.5mm screws using the Phillips #0 screwdriver.
    • Remove the fan and heatsink assembly from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 15
All Time: 560
