HP Pavilion x360 15t-br000 Hard Drive Replacement
  1. HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: step 1, image 1 of 3 HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: step 1, image 2 of 3 HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: step 1, image 3 of 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Hard Drive Replacement: step 2, image 1 of 3 HP Pavilion x360 15t-br000 Hard Drive Replacement: step 2, image 2 of 3 HP Pavilion x360 15t-br000 Hard Drive Replacement: step 2, image 3 of 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Use the Phillips #0 screwdriver to remove four screws from the hard drive.
    • Remove the hard drive from the device.
    • At the time of creating this guide, the hard drive was not present in the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 25
All Time: 933
