HP Pavilion x360 15t-br000 Keyboard Replacement
  1. HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: step 1, image 1 of 3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: step 1, image 2 of 3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: step 1, image 3 of 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Keyboard Replacement: step 2, image 1 of 3 HP Pavilion x360 15t-br000 Keyboard Replacement: step 2, image 2 of 3 HP Pavilion x360 15t-br000 Keyboard Replacement: step 2, image 3 of 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: step 3, image 1 of 3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: step 3, image 2 of 3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: step 3, image 3 of 3
    • Remove the two tapes of connected with the track board and the keyboard panel.
    • Remove the seven 2mm screws using the Phillips #0 screwdriver.
    • Remove the trackpad from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 17
All Time: 516
